I'm half embarrassed to ask this since I worked in an electrical shop for 4 years, but that was all AC and this is a whole different animal.
I bought some switches like the ones at sterlingmotorworks.com and I've figured out how to wire almost everything. What's left is my horn button. On the turn signal switch I bought, there is a momentary button that I am planning to use for the horn. The thing is that the button on the switch just shorts between a terminal (the hot line to the horn I presume) and the switch housing/handlebars. The OEM switch closes a circuit between the hot line to the horn and a green line that is on the ground circuit for the headlight.
Now I know that in DC there is no true ground, since the bike isn't grounded after all. And I know that a lot of things ground to the frame. But this seems to go against everything I knew when I did residential and commercial electrical. Won't closing the circuit to the switch housing make it hot for the time that the horn button is pressed? Will taking it off the headlight ground line cause drain on the battery?
Forgive if this seems obvious, but I'm looking at this switch and thinking it's some kind of psych experiment to convince aggressive riders to lay off the horn.
Thanks in advance
Dan
Thanks in advance
Dan
