hexinduction
So this is my first (non intro) post. I have been soaking up a lot of info lurking, but I'm having an issue I, more or less, think I need confirmation on. I have a 72 cl450. A week ago I went to ride it and it died after 10 yards or so. Couldn't start it, then I found a ground wire disconnected in the headlight. started right up. A couple of days ago I noticed the neutral light flickering and the lights would significantly decrease power. The headlight was dim and when I switched on the turn signal or grabbed the brake with the headlight on, the bike would die. Is this a grounding issue? I have checked and double checked all the black wires (in headlight and elsewhere) but it persists. I haven't blown a fuse, either. the only thing I found out of the ordinary was a poor connection from the black and white wire of the ignition coil to the switch, but after securing that, the problem still persists. Other random info that I don't think is pertinent, but what do I know: winker relay has never worked. horn doesn't work.
