Grounding the front-end stuff
AgentX
Over 1,000 Posts
So I'm building my new wiring diagram, and I have three ground leads originating forward of the head bearings. (headlight, dash/gauges consolidated, and horn switch. Horn won't ground at the bar because of the nature of the switch I'm using.)
Looking at ways to take these 3 leads back to the rear to a ground bus block.
I can :
-Put ring terminals on all three, with a fourth on a common ground lead heading to the bus block. Bolt through all of them (using brass washers if necessary to space them out) into a 6mm boss under the crown.
-Connect them to a common ground with a 4-way bullet connector, and cover that with adhesive heatshrink
-Run each individually back to the bus block.
-Do whatever someone smarter suggests to me.
Thanks for any input...
-Mike
Are they going to be in the headlight bucket?
Most stock bikes ground to the mount bolts for the headlight, which grounds to the forks, to the triples, and to the frame which should be grounded already and you're good
By far the easiest method 8)
Decidedly non-stock, and I've had no luck grounding anything forward of the head tube on the last wiring attempt. (Admittedly my first...)
Headlight is currently the 6 1/4 lamp from Dime City with the lightweight Emgo ears. Thinking about switching to a 5 3/4 style Bates bottom-mount, though.
Hmmm.
The emgos are painted which will kill your ground. You can take the paint off of the inside where it touches the fork leg and that should complete your circuit if you want to do it that way.
Otherwise I'd probably just wire the three grounds together and then run a single ground wire back to the frame to keep it less visible.
I'd previously tried to use the underside of the top fork crown as the ground, not the headlight ear...since there was an M6 threaded hole under there, seemed easy-peasy. Alas, wouldn't ground. Maybe I'll try it again on the rebuild, using a file to make sure the metal is fresh and has good, flat contact with the terminal. That'd be cool if it worked.
Otherwise, plan remains to bolt all the ground wires together via ring terminals at this hole and run the lead back from that.
