DesmOliive
Hi guys,
I've bought a GS550t with some trouble, a fuel mixture storke was broken, and no way to start it (I think it 'll start on 3 cylindre).
The plan was to restart the engine, and start working on the bike after I'm sure it's runing... reality is always different ^^
Previous owner fail to drill the rest of the screw in the carb... Not easy to find it in france, so I try to save it, I make a hole and remove the part of broken screw, use "cold welding" to stop the gap... I think it will work, see the pics (not perfect hole)
Will carbs are over, I mesure the compression... OMG ! 60 - 0 - 45 - 90 psi... we might be at 130-170 and a cylinder is down :/
Valves timing isn't ok... after adjust it, and checking valves clearance (ok), I find 100 - 0 - 100 - 115 psi.. better but always bad
Before removing the cylinder head, I ask you...
- piston seams to be ok (watching by the spark hole) and move correctly
- valves move
- cylinder head gasket is recent
what do you think it can be ? a valve who doesn't close completely ?
- valves move
