GT185 Suzuki build
bobminkwell
So I've been lurking DTT for a while watching other projects and also chipping away at my own little build- a 1975 Suzuki GT185 2-stroke. For $150 I got a rolling frame and 3 boxes of parts in various stages of disassembly but as they say the price was right.
This was June of this year:
First up as the motor was an unknown quantity I planned to dismantle, clean and reco as necessary, figuring there was not much point prettying the rest up without a viable motor to go in it. These little GTs are a bit thin on the ground in Aus and a replacement motor would have made the whole exercise less than cost-effective
As picked up in June:
All in all the more I took apart the better she looked- the right-hand piston had at some point been installed backwards resulting in the ring gouging a divot in the groove but the cyl wall was still sweet (and still on the stock bore!). Transmission oil had sat for a good while and was a bit gloopy but the trans was still in tip-top condition:
Satisfied that with new pistons and rings she would be a goer, I got those ordered from the ebay and got stuck into prepping the cases, cyls and head for paint as I had decided to go with a satin black for the motor
Prepped and taped
Down at the 'paint shop' ready for some love
Back from paint (that is, back from the other side of the shed)
long story short after much wire wheeling, sanding and soda blasting everything was painted and reassembled in mid-Aug
In amongst the painting and assembly I started trying to work out the starting/charging system. Instead of an alternator these little buggers have a DC generator, which doubles as a starter motor when power is applied 'backwards' across it from the battery. Condensers were missing initially so I picked up some generic ones to replace, points and brushes were serviceable so were just cleaned up. Got spark by turning over with a hand drill. Cleaned up the carbs, replaced the boots with some radiator hose as an interim fix and by early Oct was able to fire it up- completely untuned so rough as guts but with adequate throttle control she stayed running as long as I liked. W00t!
With proof of concept on the motor I started thinking about the rest of the build. I went with the satin black in the motor to try and give it a bit more presence in the frame- the stock aluminium finish looks a bit pokey in my opinion. Plan is to go one-up on the seat with a cafe bump, ditch the stock pegs for rearsets from a late model R6- scored for $35 from gumtree (Aus equivalent of CL). I'm relatively tall at 6'2", and this is a teeny tiny little girl bike so am thinking I may need to stretch the tank and move the riding position back over the shocks. The 'basket case' didn't come with handlebars so I've sourced some clipons from the ebay. It also didn't come with a key, or lights- I picked up an ignition barrel, fuel cap and seat lock with 2 keys from a late model gsxr750 ($50 from gumtree), going LED on indicators and tail light but am yet to commit to a headlight.
Plans from here- am painting the rims gloss black, to be fitted back up to stock polished hubs and spokes. Disc is being drilled to cut some of the weight out. Stock forks and shocks for now, will add some additional bracing to the frame then weld up some chambers. Keen to get thoughts and opinions tho.
Adam
looking good, love the engine.
those front disc ends on the gt185 are killer, if you have good tyres you can actually get the rear wheel in the air under braking.. mine used to do wheelies when the power band kicked in with the back wheel spinning,
Re: Re: GT185 Suzuki build
Zookrocker said:
lookin good...a true basket case!
Heh basket case I like that- you may just have cone up with the official cafe racer build name for this project!
Sprocket, was your bike stock, or with pipes or what? Having not had a chance to ride it beforehand I'm trying to get an idea of what to expect from any modifications. I deleted the lower cyl gasket when rebuilding the motor to bump the comp but think the pipes will be the determining factor in terms of SOP experience
it had stock pipes and jetting, but it had a rear sprocket off an srx 250 on the wheel, the sprocket i had happened to fit the gt, i cant remember how many teeth and the sprocket had multiple mounting holes so it fitted on., but it didnt have a high top speed about 95kph but was a monster if you rode the clutch into the power band..
sprocket2cog said:
..it had a rear sprocket off an srx 250 on the wheel
cool thanks for the info. i had thought about playing with the sprockets during the build but without a performance reference point thats prob a bit silly. it also doesnt help that i want it all- good acceleration at the bottom end as well as a reasonable top end but with factory top speed of ~75mph im probably pushing shit uphill on that front ha
no worries, yeah it will be a bit hard to get both, either highway speeds or a shit storm from stop light to stop light.. but play with the sprockets its a cheap way to change the delivery of the power.
Ah.. you're a brave man bobminkwell. Looking at those boxes of parts I shuddered a bit. Great start this will be cool, I like the small bikes. I just picked up an 1978 IT175 the other day and it's a runner! Will not have the base gasket change the port timing? Won't that raise the piston in relation to the ports?
Cheers, 50gary
Cheers, 50gary
Yeah it was a bit of an unknown quantity to begin with but I think I got lucky- I checked with DOT to make sure it wasn't stolen/written off/encumbered etc. and they told me it was last registered in 1988. Limited wear on everything too, just a shame I didn't get the gauges so don't know the original miles.
I have been following that IT175 build on 2SW, look forward to seeing yours.
In terms of port timing I really don't know if it makes much difference. I think AG Bell lists gasket deletion as a basic power mod, and I did shave the piston edges to maintain as much exhaust and transfer port time as possible. Even before shaving, it was only a loss of ~1mm of exhaust height. Maybe someone with more tuning expertise could weigh in?
Adam
Not much to report lately I'm afraid. My front wheel is reassembled and just wants trueing, original switch pods cleaned and painted, rear wheel is painted and hub polished just need to tidy up the spokes before reassemble. Pics to follow.
Also gave the frame and swinger some attention with a view to start getting ready for paint, turns out she's got a little bend in the down tube just inside the gusset. When I get a minute spare I reckon I can force it back in shape with a jack and 4x2s, again pic to follow.
Adam
I would check it very carefully before I put anything into the chassis? It may be tweeked beyond repair? It looks to me as if the left side is bent towards the right just above the sheet metal gusset (brace) I say this to make sure I'm seeing it correctly. Any other pictures, maybe with a short straight edge on the bent part?
Cheers, 50gary
Yeah I see what you're saying, not the greatest pic. Will grab another with straight edge tonight, for reference the above pic is taken with the frame upside down looking up from the bottom of downtube, the only bend is right inside the lower part of gusseting (the upper part in this pic). Eyeballing it I estimate less than 5° out, but enough that it has translated into some minor longitudinal rotation in the right seat rail.
