I am sorta confused. I understand that the prevailing idea on triples is to run a slightly larger main jet in the center cylinder carb. The idea being that the center cylinder is going to run hotter because it is pancaked in between the other two cylinders, therefore get more fule in there to cool and lube the piston.
I looked in my shop manual and it said the stock jetting is size 95 jets on the two outside cylinders and size 92 jet on the inside!!!!! When I took my carbs apart I was pretty sure there were 97.5 size jets on the outside cylinders and a 95 jet in the center. Ok, that follows the idea in the manual, a smaller one in the center. But why a smaller one in the center???? Isnt that the hot cylinder, ie needs more fuel to keep heat down???
So anyway, I went up to 110s across the rack of three carbs and raised the needles all the way up, which is only one clip above where they were. I fired it up this morning and the two out side cylinders were popping strong against the palm of my hand. The center cylinder felt weaker and not firing as often. I ran it for a few minutes to seat the new rings in. After a little while I noticed the middle cylinder pipe was not firing at all and the outside two were popin strong.
I pulled the plugs and I think it didnt run long enough to really see any coloring difference. They were a little brown and wet. I suspect that maybe the center cylinder was gettin too much gas and gas fouled the plug. That is why it was not strong at first and then went out.
Anyway, I was considering dropping the center carb main jet down to a 105. Now that I think about it, just running it in the driveway, the main jet would not even be in play correct??It would be running on the low speed jets and maybe the needle at midrange.
I am going to have my brother come over and tweek with this thing. Maybe the timing is off. Maybe there is a weak coil to the center cylinder?? We will see. Just baffled as to what caused the burn through. Also, the center cylinder did seem to be runnin a little weak prior to the burn through.
*****Any two stroke tunin gurus out there with some input for my dumb ass?????????****************
Gonna check the ignition timeing, coils, wires, jets, every freakin thing!!!!!!!!!!
One thing for sure, when this monster is dialed in correctly it is gonna RRIIPPPPPPPPPPPP!!!:shocker:
