guage removal
johnny gaijin
hey guys, i'm planning on removing the guages from my cl360, unfortunately i don't know much about motorcycles (or other engined things). what's involved? anything to look out for? pretty easy? pretty difficult?
thanks!
Taking them off is easy, just get a big hammer ;D. Are you taking them off to leave them off or just to work on something else? If you are leaving them off you will have to find plugs for the speedo/tach and cap off any illumination wires. If you are just getting them out of the way you will have to unplug the wires behind the headlight (be sure to put tape on them so you can turn the ignition switch without blowing a fuse) and unscrew the cables being careful not to put any kinks in them.
That's one thing that I don't know but wanna find out too. I would guess that just any old bolt would work as long as it doesn't interfere with the drive itself and keeps oil in and dirt out. Even if the shortest bolt you can find interferes with the drive maybe you could drill out the center of it?
anybody else have any tips on guage removal or ideas for plugs? waiting for sunshine on a day off before i tear into it and would like to avoid surprises.
Taking off the gauges will be pretty easy - you just unplug the wires and the cables, unbolt the gauge and you're done.
For plugging the tach at the head, is it a screw on cable or a slide in type? If it's the screw on, you could cut the cable and use the screw end (with a washer inside). If it's the slide in type, go to your hardware store and look for the rubber plugs that you put on the feet of chairs. You can get them in pretty small sizes, so you should be able to find one to squeeze in the hole.
They will melt, cam cover does get hot.
I made some alloy plugs with 'O'ring seals. you can buy them for CB350 racers but I like mine better ;)
PJ
How-bout this?
more in my 'yet another CB360' thread, big arse projects
PJ
johnny gaijin said:
will a 350 plug fit in a 360 engine? if not are you selling plugs, pj? ;D
They should fit but I didnt't particularly like look of them, bit bulky.
I can make you one of 'mine' if your interested?
PM me.
PJ
