h4 headlight relay
Djfob
Putting together my own hi lo relay. My question is should I run a new ground right off the battery or use existing h4 plug ground wire?
Using 20a relays from eastern beaver.
The coil doesn't need a lot of current, so a shared ground is O.K.. why not a separate ground to the chassis? The coil doesn;t need to go all the way back to the battery.... The headlight ground wire should be a heavier gauge then stock and it could go back to the battery though. More 12V power on the + side needs a good return. The ground side of a lot of motorcycle electrics is almost as bad as the supply side.
I use two of those. One for Hi and one for Dip and grab power from a PC8 courtesy of Eastern Beaver. I also use one for ignition. That way the power draw through bar switches and grounds is minimal. PC8 has its own hot and ground leads, so if you are making a new harness or modifying an old one, that's the way to go.
