Hagon VS progressive?!?
i haven't had hagons on my bike, but i love my progressives. beatnic is a smart dude though, and he probably knows more about suspension than i do.
Ok :) beatnic i was thinking about those hagon's is that a good choice?
I think the base is all the same for all there shock right?
Mine will have black springs and I'll might paint them red :D
Thanks go ( and Rich ) for the props. =)
joevirus563, no matter which pair you decide on, you are getting a huge improvement over the stock shocks. I think the Hagons are a slightly better choice between the two you asked about. ( I have no experience with the YSS )
The deciding factor for me is the fact that they give you different damping rates to chose from. You'll be able to get a shock that is more "tuned" to your needs. I would call or email tech support for both companies, tell them what you're looking for, and see what options they give you.
The clevis ( you typed base ) should be specific to your bike. As long as you specify the application, they should have the correct mounting type on them.
FYI the Roadshocks pictured are [red]not[/red] adjustable other than preload. If you want dampening adjustment you need to look into the "2810 adjustables" (farther down the page)
note the dial wheel at the bottom of the shock:
If by base you mean "core" then the difference is between adjustable and non adjustable beyond that it's mostly just choosing if you want covers, or polish or slimline springs.
mysta2, yes the ones joevirus posted are not damping adjustable, but when you order them, you get 4 different dampening rates to chose from ( soft to extra hard ) and min of 2 different spring rates.
Thats what I was refering to when I typed different dampening rates to chose from, and "tuned" to his needs. Not external adjustability. ( other than spring preload ).
I wasn't on the same page... then for the same price the progressive are beter... no?
I just ordered a set of Hagons and installed them on my RD400. I haven't ridden them yet because the motor is blown, but I can give you my impressions thus far.
First, you have to get David on the phone and chat things over with him. He understands this stuff backwards and forwards. From there, you collaborate on what spring rates to run and damping characteristics. I went with a 1" longer damper with the slim springs and middle of the road (fixed) damping. The set up was ridiculously cheap--something like $160 delivered (but don't quote me on that).
Quality-wise, they look pretty decent. I got the black bodies with the black springs. I'm pretty happy with them.
--Chris
I don’t have any experience with them, but they don’t seem bad. You get rebound adjustment, spring preload, and are rebuildable. They match the spring rate to the bike and rider.
The yss are g-plus series and are preload ajustable and are gas and oil filled. Price is 300$ us including shipping. No rebound ajustement...
What do you think?
What do you think?
I found that progressive have 5 preload ajustement VS 3 for the hagon.
The Progressive and Hagons will be gas/oil shocks also. I think having 4 different damping rates to chose from ( Hagons ) is a bigger advantage than more spring preload adjustments.
Ok cool but You chose when you order?
On the Hagon webpage they list 4 different damping rates and two different spring rates. Call or email their tech support, tell them what what your bike is, what your weight is, what kind of riding you do and what you're looking for out of the shocks, and they will recommend the best option for you.
:) OK I'll go with Hagon's... :) but can't find the dampering options on the website, do you have a link?
mysta2 said:
Call them
I did and they only talked about the spring weight which is 18kg and falls in the Medium dampering categorie, you don't have the choice from soft , medium etc in each spring weight.
