JRK5892 said:very nice tweek very nice! I wish i would have changed the gearing on mine while i had it apart... still may... just ordered new gears for my FZR... should give it a bit more pep
mick22 said:awesome man. a few questions, how much were the tires and from where? are those shocks the stock ones just powdercoated? and finally, are you doing pods and if so, what kind of jetting are you planning on doing on your carbs?
+1JRK5892 said:WOW man that frame is TITS! for real..... just bounces color off the black! loving this combo!!! looking good!
slushie07 said:![]()
What compound(s) did you use to polish those gauges, they look great.
adamrjordan said:The silver frame with black and chrome parts is a great combo.
What brake line are you using and where did you get it from?
awesome build.
Adam
JRK5892 said:I do the same thing!!! only i use WD40 to lube as i am polishing.. i have a high speed buff wheel and water does nto cut it... the WD works great!! but you can not use it in the same room as you will paint in... EVER... or your paint will never lay right
tweakin said:
tweakin said:Changed the gearing to 15 front 37 rear to give it a bit more pop.
Cleaned up the pistons, now waiting on new rings.
Rebuilt the front caliper and master cylinder.
Getting a bunch of stuff back from the powdercoater next week. Hope to have it back into a roller by next weekend.
