edelweiss said:What type of tools would be used to hammer in knee indents into a stock CB500 tank or any tank for that matter?
Thanks!
edelweiss said:If I wanted to do this to a bare steel tank like yours, can I use some sort of finer metal-working hammers to smooth out the nasty dents the mallet makes? I want to have a steel tank in the end.
Thanks!
VonYinzer said:Basically... No.
Only real way to have perfectly smooth indents is to make them using proper metal working tools and graft them into the tank.
SaltCityCafe said:
carnivorous chicken said:Just out of curiosity, was this enough to talk you out of trying this?
CupidsDeathDay said:My buddy used a mallet to make his just fine without grafting.. He just went in later with some bondo over the dents, sanded it, smoothed it out and painted it and it looks great! But I don't know if anybody else wants to go through that trouble.
Hot500 said:If you have acess to a tig or a friend with one this idea might work for you.
Mark out the knee indents with a paint pen making sure both side are exactly the same size and shape.
Cut them out using the finest/thinnest cutting tool you can get your hands, on and then swap sides with the peices you have removed.
Now the peice from the right side of the tank is welded in its inverted position into the left side of the tank and visa versa. Hey presto, knee indents. File back welds, bondo and shape to suit. A lot quicker and neater than bashing it with a hammer.![]()
Walms said:It does sound clever, although I'm not convinced it would work unless you had a uniform shape (sphere)
Green199 said:That way does work. A lot of guys on this forum have had success with that method.
Walms said:I would think the cut would have to be on the same plane... Let's say you used a piece of tube to draw a circle on the tank, it would need to touch all the way around the perimeter to work, if for what ever reason, you don't have contact in a certain area, that area will not be a perfect fit on the opposite side.
