handlebar blues
chillinfellow
Just put on a dragbar, cables end up with to many bends from the way they are routed with the extra slack in them causes the bends to be more severe (especially up top behind headlight), throttle wont return either ( did see the previous post with the clubman bars will try some of those suggestions) clutch cable ends up laying on exhaust too, also I cant get the bars centered because of the front brake hose fitting ends up butting up to the side of the tach leaving the bars about an inch or so offset to the right, assuming I am SOL and will have to probably pick up a wider set, bought a 28" wide set, noticed there are some 30" ones out there, from the looks of things seems I will need to reroute the throttle & clutch cables to allow easier movement (less dramatic bends in them) * cables are routed threw center of fork behind headlight, clutch routed left center, throttle routed right center, maybe flip flop what side they come threw to eat up some slack and ease the degree of bend in the cables? wider bars ? what else can be done to take out/remove excess slack ?
You have re-routed the cables?
Ignore stock routing and just use largest radius bends you can get
Probably going to need a different master cyl, find one with front or rear banjo instead of on the end
have not rerouted yet do plan on it now, did chat with a local shop guy today also, he said he could shorten cables no problem if need be, pretty easy one to do for the type of bike it is he said,(78 kawa kz400) yes did look at other Mastercyls out there, pondering which direction to go, either new 30" bars which probably will give me just enough clearance or stay with the smaller bar and replace mastercyl, bars only $30 delivered still pricing out masters new/used etc, yes I will focus on the banjo styles you mention. Thanks for your input Hillsy & PJ it is appreciated, will update soon, need a few days before I can get back to start reroute cables and order bar or mstrcyl.
well did get the new bars were a little wider than I wanted but after all is done & said I can live with it, rerouted cables and had to reset clutch cable ( was really messed up from lever down to chain cover by previous owner ) works
much better now too, front brake lever has plenty clearance now, bottom line everything worked out very well, patience and logic with some good guidance seem to be effective while navigating through situations on these older bikes especially for noobs like me. 8)
