having trouble rotating the ac gen. rotor
72cb350
im having trouble rotating the disc that i have to rotate to line up the "LT" with the stator index mark. do i romove the screws or.......???
More info.
Remove the alternator cover, then there's a 14mm bolt in the center of the stator. Turn this counter clockwise with a 14 mm wrench. If it doesn't turn you have much bigger issues.
Like I said bigger issues.
You have a lot of reading to do.
But basically there's a few ways to unstick the engine all of which can be found on this forum using the search
Check out this website: http://www.dansmc.com/mc_repaircourse.htm, it has lots of great info on DIY motorcycle repairs and maintenance. Here's the section on unsticking a seized engine: http://www.dansmc.com/stuck_engine.htm
