Header Wrap Zip Ties
HerrDeacon
Over 1,000 Posts
I'm wrapping my headers and using the stainless steel zip ties to secure the wrap to the header. The only problem is that I'm having a hard time getting the ties really tight. My understanding was that you just had to pull them tight but for some reason mine are still a bit loose. Loose enough that you can spin them around. Not much use like that.
Any tips on getting these buggers tight?
do you have any header tape left and can you loosen the straps.
if you do and you can take a strip long enough to wrap the pipe twice cut it in half (1 half for each strap) wrap it where you want to put the strap and tighten the strap to it. if this is not possible. take a flat head wide blade driver and place it under where the strap comes out of the buckle. grab the end of the strap with a locking plyer and puch with the screwdriver and pull the plyer.
good luck
I tried the screwdriver trick, but I couldn't really get it any tighter. May try it again tonight. Thanks.
I've never seen these 'zip ties' in stainless - I though most folks used the hose clamps that screw tight. Got pics?
I don't have pics of mine but they are the same as these: http://cgi.ebay.ca/25-STAINLESS-STEEL-CABLE-ZIP-TIES-EXHAUST-HEADER-PIPE_W0QQitemZ110244422724QQihZ001QQcategoryZ35573QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
There are a variety of tools available to tighten plastic ones...
http://cableorganizer.com/cable-tie-guns/
But I have no idea if they would work on SS ones.
I did find one on this UK site... http://www.cse-distributors.co.uk/cabmgmt/stainless-steel-cable-ties.htm...
but I don't think you're going to want to pay the price :o
good luck
This is exactly what I did. Pull really hard! Though more difficult to apply, I think the proper ties look best.
--Chris
Yeah, I like the look of the ties better so I'll try again to get them tight. However, if I can't I'll have to go with the clamps.
You ever try stainless safety wire like us race guys use to secure nuts, bolts etc. With spinner pliers you can get the wire really tight and the wire should pretty much disappear into the wrap, then just fold the tightened end out of the way.
Sounds like a good idea. I could actually use both since the wire wouldn't really be visible.
Is this wire something you can buy at a hardware store?
Go to pretty much any bike shop and they can order it, though it does usually sell in a one pound can. So if a few of you get together and split the cost, you can have a pipe wrap party.
The wire pliers look like this, and get them, twisting by hand will never get the wire tight enough. $9.99 on sale at Princess Auto.
Here are pictures of what you'll need and the link takes you flickr to show you how to do it.
http://www.flickr.com/photos/rodneywills/1938476747/in/photostream/
I plan on using safety wire myself, i picked up a 1lb can for 23.00 (US). I don`t have the spinny pliers yet but soon.
Finally got some time to try the ties again. I used the suggested method of the screwdriver and vice grips, worked great. I also wet the wrap again to help stop the tie from sliding around.
Thanks for the help.
