Headlight idea?
my-79-750-k
Therapy is expensive. Riding is cheap. You decide.
OK, so I'm kinda not liking the giant single headlight on the CB. I'm thinking of making some kind of wiring box to blend in to the front to take the place of the bucket, and then running two of these in 3" or 3 1/2". I'd mount each one to each of the original mounting ears. Only drawback is, they're only 55W and have no high beam. Maybe I can find some with hi beams, but would it work since they're made for cars, would the wiring be any different?
Your biggest problem is gonna be the current draw - two 55watt bulbs is massive.
unless you only have one on at a time of course. couldnt you run a H4 bulb to get a high beam?
Google dominator headlights and you'll find the generic twin streetfighter style headlights. They are far easier to wire-up / use as they come with hi and low beam already, and they bolt together side by side so you can mount them between the fork clamps securely.
If you really want to run those style of fog lights, you can run one as low beam and wire the other for hi beam.
I thought about that hillsy. I'd just replace one of the 55w with a 60w and rewire the switch to swap over to the other light when/if I ever use my hi's? I don't really want it to look "streetfighter"ish. I just think the big single bulb looks like a harley front end. I'd still have to have something there to hold all my front end wiring, but I could fab something up at work for that.
These are easy to fit, have high low and sidelight.
I fit Yamaha 'Genesis' bulb, 35/35
