Headlight mounted Ignition switch
Slantyface
Hey all
So, since I've decided to mount my speedo in the center of my bars on the top tripple, now I have to come up with a location for my ignition switch. My thoughts were to put it in my headlight bucket. The factory switch is way huge for the bucket, so I picked up a 3 position switch. Hooking it up is simple enough too. Anybody else have this done? Do you like it? Are there any drawbacks? Thanks guys
I mounted my ignition switch to the headlight bracket, then ran the wires into the headlight for terminations.
I used the factory Honda switch(Red Plastic), which is also too big to fit into the stock headlight.
Thanks for the recommend on the ear! Emgo makes this particular switch. Super cheap too. Like 12 bucks is full retail, so I'm sure you can find it cheaper than that too. Manufacturer part number is 40-64000. Should be a pretty easy find. I decided to put it in my headlight ear just for plain ease of installation. I put it on the left side where the bucket behind the ear is indented. Originally the indent was to allow room the the stock speedo cable to go unobstructed. The new switch has an accessory, off and run position so I feel like I can retain most of the factory usability too. Now for some eyelet connectors and heat shrink and I should be ready to go!
Anyone else have experience with these? Mainly seeing if they are a reliable unit.
They work for awhile. Not the best in the world, not the worst. If you get one designed for a tractor they seem to hold up better. And the tractor ones are usually about $10 plus sales tax (unless you have a farm exemption, like I do)...
For the length of time I'll probably own this bike I hope it'll hold out. On the bright side the install only took about 5 minutes, so if something goes wrong it's an easy fix.
Guess if it fails. Could just Hotwire it to get home.
