headlight relay question
pterodactyl
I got a good quality headlight relay for the xj 550 and it seams work
But man does it buzz.
Is that normal?
Relay On The Bike Wire Color
Output Dimmer Switch Blue/black
Battery Fuse Box Yellow/Red
Hot Wire Trigger Diode Block White
Ground Trigger Ground Black
This is how the relay matches the terminal now
OK. That makes sense.
The Panasonic relay, is it an automotive style?
If so, it should be numbered with the following pins: 85, 86, 87, 30
Pin 30 to yellow/red (fuse block)
Pin 85 to white (diode block)
Pin 86 to black (ground)
Pin 87 to blue (dimmer switch and gauge lights)
Thanks, It does have those numbers.
So if I'm looking at that right my black/ground and my white/diode are backwards?
Pins 85 and 86 aren't usually polarized, so they can be hooked up in either direction. I think you much just have a funky relay.
