What did you do?
retrace the things you did before it stopped working.
If you did nothing check bulb for continuity (link has already been posted to cheap meter)
You can get digital from Harbor Freight even cheaper, it was $4.99 when I bought it http://www.harborfreight.com/7-function-digital-multimeter-90899.html
You need a volt meter. Turn the key on so the light comes on or what should be on. Start the bike and run it if you want. Now probe the socket were the bulb plugs in. Do you have voltage? If yes bulb is bad. If no start walking backwards in the system. Look for an unplugged wire in the bucket. I dont know if you have a fuse block. Check fuse. Check for voltage on BOTH SIDES of the fuse in the block. You could have a bad fuse. You could have a crapped up connection. You could have a broken terminal in the fuse block. Like I said I dont know if you have a fuse block but its power related if you do not have power to the headlite.
