helicoil or timesert
stroker93
I have a "boogered" plug hole on the 360t,,I have never attempted to helicoil or timesert a plug hole while head is on bike..I have heard timeserts are better,,not to gung ho bout tearing head off,,gotta read more bout timing cam and crap..
Dave
I'm a big fan of helicoil-ing holes myself. I use it all the time at work. However, if the holes not too boogered up, why not just re-tap the hole? Let's assume it's boogered more than that. You're gonna have to drill it bigger no matter what. Best bet, is get a extendable magnetic pick-up tool to go into the cylinder and remove the shavings after you drill and helicoil the hole. (Assuming your head isn't alum.) A bagless vacuum with a small hose taped to the vacuum hose will help with the removal of the metal shavings.
Unless you can get hold of copper plated Timeserts, use Helicoil (or one of the generic brands)
If your going to do it with head on, back adjusters out as far as you can so when you turn motor past TDC you don't clip a valve because it's open.
Greasing the tap is more effective with alloy head.
Make sure you follow original hole or plug probably wont seal if it's 'tilted'
Whats the reason for copper plated?
Also check out E-Z Lok inserts. its a solid insert like Timeserts, but it doesn't require all those special cutting tools.
I've never used them for spark plug holes, but I used them for head studs that went into a water jacket and they worked great.
Pretty simple
Normal Timeserts don't transfer heat from plug into head as well as copper plated ones.
They were available copper plated specifically for spark plug hole about 30 yrs ago in Europe
Helicoils, because they are parallel and spring loaded into head, transfer heat better even though stainless steel isn't anything like as good a conductor as aluminium
