hello. lets talk engine set up.
supercafe
Coast to Coast
i am making a cd 175 cafe racer, and i am wondering about what exhaust and jet set up i should use to get the most out of my bike.
i am new at this and would like some help from guy or girls that have done this before.
straight pipes or not?????????????????
thankx.
come one guys no one out there with a 175. i'm not sure what jets i should start with,
using mufflers with removable baffles, i want to run straight and on ocassion run the baffles.
so any one out there know any thing to help, it would..
thanks.
build the chassis first...to what ever specs you have in mind(lets slam it to the ground,,,and handle like shit)or!!!! put in good oil in the front forks,buy real shocks(not old rusted shit) good tyres,,,,build the bike to handle first...then build the motor!!Honda's if they have had any oil in the botton end and sitting and turn free,pull the top end off,hone or hand sand the cylinder walls,are the rings free in the pistons???hmmm the valves rusted from sitting for 20 yrs,,,,,and what about the carb's...plugged solid,,,,,,,,"it doesn't run on both cylinders" :o.......no shit!!!!!!thats the way I bought it!!!!!! as for your straight pipes,,I hope you live in the country,,,cause somebody in the burbs will kick it over and set it on fire..if they have to listen to that at 6;00 AM
thnks for the reply.
my motor is all stock right now, and runs awsome. but i was wondering what jets i should start
with, really need to know before i buy any. as for the exhaust i have never herd these motors
with straight pipes, only on u-tube. but i like it.
i have mufflers with removable baffles.
thanks.
later..
run the muffers,remove the baffles,start with the stock jetting.EPA and CARB didn't exist back then,(or they weren't anal)which means they are usually jetted on the rich side. In the 80's to present jetting is considerbly leaner due to the emission restrictions(cast in pilot jets,,,,keihin!!) I have a cb 350 road racer and was TOLD to run bigger jets when building the motor,I did and then I leaned it out back to stock jetting(105 mains),,,one question,,how do you herd motors? ;D..good luck
hows it going. thanks for the info. i will try the stock jets first, with the baffles out. you think that this is the way to go??.
i was told that running straight exhaust could cause burnt valves, what do think about this. i'm on the fence
with it. i guess it could if it does'nt have the right mixture. whats your take on this???????????????????????
with your race bike you have straight exhaust and stock jets?????and i would imagin that it runs great????
if this stock jet set up doesnt take what jet size do you think i should go with, one size or two sizes larger??.
i know it is a trial process, but the closer i can get it the better.
any way thanks for the info and advise.
thanks, later..
Trial and error,run the bike under load,(full throttle)don't move the throttle,hit the kill switch coast to a stop and pull the plugs and check the colour,,rejet accordingly good luck
thanks man.
so adj the jets according to the plugs. after full throttle.
seems pretty basic. i will do so when its running and the snow has fled.
so to reask another question. if i run straight pipes would i run the risk of burnning valves?????????????
lets say even if the plugs look fine and the mix is pretty close??????????????????????.
thanks i lot for the help guys, i'm new to the setting up thing.
later..
carb voodoo, tis an art, what Wee Todd said is exactly what a motorcycle mechanic friend of mine told my to do when re jetting my vespa after i put some performance parts on it similar to what you are doing, aka performance pipe and free breathing carbs
a good tip is, it is always better to be running a bit rich than lean and i tune all my bikes and cars to run a bit rich if i do any changes to the engine
good luck
thanks, for the replay.
when i get it started i will do this. and hope that the stock jets will work o.k.
i'll keep you guys posted.
thanks.
later.
thanks.
later.
Hey,
I did this for my CB175 last year since my mufflers were rested to shit and had no baffles anymore. The best thing to do is to get a a few different sizes (1-2-3 sizes bigger) and do trial and error. That said you say your bike ran well with the stock exhaust, it will probably run well with the baffles and the jets you already have as the back-pressure may be close. You may need to go up one size, but you will still have to finetune the needle clip position and mixture settings on the pilot jet. The jet size is most crucial for full throttle, high RPM applications. Mid range / low RPM are mostly determined by clip position and the mixture screw.
The rule of thumb is that the air filter can affect jetting up to 5 times as much as the exhaust. If you are making any changes to the intake, you will definitely need bigger jets. Regardless, they are cheap. I got my jets at http://www.northcityvintagehonda.com and I got 3 sets for about 15$ shipped, taxes, duties and all at my door in Canada
You should read this, it's right on the money
http://www.motorcycleproject.com/motorcycle/text/cows-jetting.html
Cheers,
Guy
whats up magnang.
that web site is awsome, lots of prts. will be ordering the jets from them.
and thanks for the help, always good to get help from people that have been there
and done that.
thanks again
later.
I can tell you that on my 360 I have Uni Pod air filters and stock pipes with reverse de-baffled megaphones. I have not had to rejet. The bike is fast as hell. I know that the right side is a tad lean because the manifold has a small dry rot leak. It isn't too bad, I have new ones to install. My point is, I have really freed up some air and I don't have to rejet. the bike is pretty close to perfect. I'm sure I could maybe get a pony or two somewhere, But the bike runs great.
I'm not saying yours will be as lucky. But install the carbs stock and go for a ride. Test and feel the bike at all rpm ranges. Start slow, two or three blocks between 2k and 4k RPM in second and thrid gear RPM. then stop and make some notes. Do it again in different range. HTe way I test WOT is on a four lane in second or third for about 5-10 minutes. Hit the kill and pull in the clutch before turning back the throttle. (use an off ramp) Take out each plug and look at it. If it is white and ashy, it is too lean. If it is black with carbon, It's too rich. If it's tanish it near perfect. You could pull the plugs after each range test, but That's too much work for me.
Ah yes but do you know for sure which jets are in there? The previous Owner could have re-jetted without you knowing, and the bike might have gone from rich to just right from the changes you made.
The bike only had 8500 miles it was in a guys garage for years with a broken clutch cable. The guy says he never learned how to work on bikes, this was his first and last. It was stock with the original mufflers. It's a good bet that they were OE.
whats up guys.
thanks for the input. yes i am going to keep the stock jets for now.
but i am going to take it apart and clean every thing up. maybe get a
new needle. i have talked to a couple people on here and they say the
same thing, even with straight pipes. so i'll try it.
thanks again.
later.
I never get excited about plugs that are a bit sooty. I'd rather run it a bit rich as well, as compared to holing a piston.
