Before everyone jumps down my throat- I have researched this! I get lost in the technichal jargon of it all so please go easy on me. As you can see in the pics the green wire between my rectifier through the square connection, all the way along the wiring harness to where it splits near the coils, is melted. The pigtail that connects to the frame looked like it was starting to melt too. The other green wire that came off it to the headlight bucket was fine. Now, does this lead you to assume the rectifier itself is bad or maybe that length of green wire just had a short or both? I haven't had the bike for long, and only ran it a bit, but it did appear that when I put a volt meter across the battery terminals the voltage stayed the same at idle and when revs increased, so not charging. Would that play into this melted green wire?
My feeling is that I should replace the rotten green wire, then do more testing of stator/ rotor/ field coil. But should that rectifier be replaced too?
