Frankenfe
Coast to Coast
I picked up a 1975 CB75F0 engine for my current build. Cosmetically a Very nice engine, but there is a problem.
The Crank will only turn 1 & 1/2 rotations (540 degrees) before it hits or stops against something. it can be turned 1 & 1/2 turns either direction lock to lock.
I am very suspicious that it has to do with the kick start gearing / return spring, as it does not seam to operate properly. won't return fully and does not dseem to provide a "Full Stroke".
I would like to adress this issue before anything else.
1) What could cause this scenario?
2) If it is the kick start, would it possibly be a bad tooth on the kick start gear? or simply an issue with the return spring?
3) If it is the Kick Start gear, this requires splitting the case, Correct?
Anyone who has experienced and resolved this issue, I would appreciate your advise.
