HELP! CL175 ran yesterday... carbs?
iamjjr3
Active Member
I'm a bike noob.. FYI. :)
I recently bought this bike and it always started up first or second kick. Ran well
but sounded a little off when I would accelerate hard. I decided to do a quick clean
of the carbs and brushed all the dirt and whatever off.. didn't remove the float or
anything (only did one carb). I put it back together and ... then the bike didn't run.
When I was taking off the carb I took off the spark plug on that side (right side)
and the plug housing came off of the wire (and now I need a new ignition coil).
I checked it and it still had spark so that wasn't the problem. Tried to push start it
and it still wouldn't fire up.
I have no idea what happened. I took the carb off, cleaned it up a little but didn't
touch anything. After it wouldn't start I played with the air and fuel adjustments
trying anything but.. still nothing. Took it out again, the float chamber has gas in
it so I know its filling up. Dunno if its at the right height or whatever but like I said..
It started up before I took it off and I didn't mess with any of that.
Help!!
Have you checked for spark? If the motor needs tuned even slightly, it wont run on one cylinder. Check both sides for spark. And make sure your battery is holding a good charge too.
Well if the wire came off you can still save that coil dude, I made a video of it on my youtube. here you just have to be careful when breaking the porcelin. I just used a sharp chizel along the seam.
How to save your coils
thank you!! I am going to try that. It did have spark, but I don't know if it had enough voltage to actually start it.
After this, I decided to just take out the engine and start from the frame up. Good thing too because it it was
pretty bad. I'll be posting pictures of the progress.
Thanks again!
No problem bud! Anything else you would like help on? I could post a vid of it real quick.
