Yep ;D
You'll need to remove rocker cover, then slide cam side to side.
Some motors need shim, some don't.
If your pulling rocker cover, there are two bolts under breather cover.
You also need to remove valve covers and loosen all the adjusters ready for reassembly. (ggo chance of bending valve if you try and cut corners)
Should only take an hour or so to check/reassemble (probably take longer to find a new shim if you need it)
