help help help
pyro139
1981 cb650c
haveing some probs on front end need some help adjusting front forks redoing break,s and removing wheel so can realighn,
if some one with more muclse than me, a mobile air gun set up or a heavy tourque whrench want come give me a hand in labour and knowledge :-X
I cant help out tonight...
use a jack from your car and piece of 2x4 to lift your bike's front end 2 inches so that you can remove the front wheel.
Thats what I do...
Thats what I do...
i'm weak cant get axle out :D
Does your 650 have an axle up front? because my wheel just comes off after removing the two bolts thats clamp the axle to the forks. Just curious, what do you mean realign? I took my front wheel off aqnd removed the forks to change the headlight ears and i just bolted the wheel back on. Should I be aligning something?
81 cb650 has a different kind of fork, and what i mean align is the two forks aintat same level, need remove wheel to correct it properly.
81 has a bolt in axle where 79-80 and 82-83 cb650's has a drop down axle where you just remove bottom clamps, the 81 is alot trickyer.
honda tried alot of new idea's on the 81 by 82 they scrapped half them and went back to what works :D
ha ha i see. i guess i got lucky :D
79 ans 80 owners are lucky ones, they have traditional spring of hydrolic forks, not the crapy air over hydrolic that 81-83 650's have.
pyro139 said:
the want just trade me the 550 for a half dissembled 650? :P
Sure Ok...so, ur gonna give me $5000 + a half disembled cb650...for my cb550f.....Sounds like a good deal...
locOleoN said:
Sure Ok...so, $5000 + a half disembled cb650...for my cb550f.....Sounds like a good deal...
wow people where wrong saying your so mean you going give me a 550 and $5000 for the 650 :o
k bolts are loose so can work on bike, was able get ahold of my step farther 6foot 7 240 pounds better than any torque wrench :D
