Help! How do I mount a aftermarket carb to my engine 1978 (CB125s) (RESOLVED)
benngalaska
Hello all. I need a new keihin carb for my honda cb125s. After hours of searching i have only found carbs that have a mounting scheme like this (see pic 1) but my carb looks like this (see pic 2) and the top of my engine looks like this (see 3&4) I cannot se ow a mounting flange works on this type of system. Also what does that metal thing do on the engine hole. all the carbs on the internet have one of these see pic 1 and i cannot see away around it thank you for helping me>
1
Re: Help! How do I mount a aftermarket carb to my engine 1978 (CB125s)
OK the top carb is called a flange mount and it can not be used without a flange mount carb adapter that has an angle on it . . this is a bit of a pita so I would simply buy a spigot mount carb like your original . . mikuni and possibly keihin make them . . if your bike is high perf you might want to get a 2 mm larger carb . . if you need help finding a carb I can help you or someone else also can . . you might need to modify your throttle cable.
Barnett
Thank you very much! I just looked up spigot carb (VM24) and I found exactly what I needed. My Bike is a cb125s. Thanks!
No prob . . keep in mind the air box side of the mikuni is bigger than your orig so your stock air box boot will not fit.
buy an original carb or make a boot or modiify yours . . you can heat the boot up in boiling water and try to stretch it over the carb but in your case i dont think it will stretch that far . . isnt this fun?
