jmal18 said:Took apart my carbs for the 12th time and after putting them back on both float overflow screws are spewing gas like crazy! Everytime I come to a stoplight and idle the bike dies bc one carb is flooding with gas! Pretty sure my float levels are right... WTF!!!!!!!!!
Big Rich said:Check that the float needles are in there and not missing, upside down, or dirty.
Does it flood right away or only after gas is in the bowls for 20 minutes or so?
dirtbag said:How are you setting your floats? Do you have a tool or a caliper? Did you put new float valves in?
dirtbag said:see if they are functioning correctly as well. test with water.
jmal18 said:my starter button is broken and is t making good contact?
bikeboy said:bad contacts in the starter button will only effect the operation of the starter. Once the bike is running it has no impact.
cheers
ian
Gas seems to b flowing fine, I guess I should take the fuel lines off and see if there is a blockage there. I haven't changed the slow jets at all. I could I guess I could turn the idle screws in all the way and see what happens. Really frustrating to tune bc battery dies so easilyBig Rich said:The larger mains have almost no effect at idle. Did you put in a larger idle jet?
They might be clogged... Whats the verdict on the gas flow situation?
