HELP lighting problem!
Bobby4Prezz
no matter how i hook these lights up http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280413115948&viewitem=&sspagename=STRK%3AMEWNX%3AIT they won't blink, they stay lit, until i hit the turn switch and they turn out. please help!
its a hondamatic 400a, i took out the headlight to look at the wiring, if i hookup old lights they work, but when i pug in the new lights, the same as the old or any other way it just stays lit (running light) or goes out when i hit the turn signal. or it will other way around, no running light but when i turn on blinker the light comes on. but the old ones work fine, just trying to update the look.
If i had to hazard a guess, id say those bulbs probably dont pull enough power to trigger the flasher relay. You can look into getting a universal flasher relay, the same as would be used for LED signals, that might fix the problem.
Quickest way to tell would be to look at the base of the bulbs and see what kind of wattage they pull, i bet its significantly less than the stock bulbs.
Ahh, you've posted this twice but the fact you've said here that the old ones work fine, new ones don't makes me agree with the fella in the other thread. Electronic flasher can. Go get one and plug it in.
