Help on ignition? electrical?
funkja
Active Member
so i need a walkthrough/howto on narrowing down whats up with the bike. here's the rundown:
80 cb750C new battery, all other stock. it ran fine all last summer, and sat all winter in storage. It does run still, and runs just fine. no starting power. If i flip key to run, and hit starter button then nothing, just a single click and starter does not engage. I can roll it and start it on a hill in 2nd first try every time, and it'll run all day but once i kill power it must be push started again. ive check all fuses up in the console and the big one on the side near the rectifier (i think thats what it is)
I have a multimeter, just need someone to walk me through what to check and where on narrowing down the issue. any takers?
edit: or more helpful even if someone has a CB750 electrical fault finding chart i can follow.
i'll hafta get it charged up fully again. ran it out around town for a grip, kept the rpm's higher than i normally would. it's been sittin for 2 hours and battery measured 11v terminal to terminal. is that a little low with the bike off?
Should 12.8v for a fully charged battery in godd condition.
What is the voltage at the battery when the bike is running? Should be 13.5 to 14.5v at above 3000 rpm. If this checks out, your battery is shot.
This is how I troubleshoot. Look at the schematics and find the problem. (starter)
Does the starter work? If you unhook the starter and hook it directly to a 12v source does it spin?
Trace the problem back into the diagram and see what it is hooked up to. (ground, and Starter magnetic switch)
At this point check connection on starter to ground wire, check continuity from starter magnetic switch to starter.
Then check the wire from starter magnetic switch to battery for continuity.
Then put power to starter magnetic switch to see if it actually works, you should hear a click. And follow the circuit all the way to the start switch for continuity.
The idea is start at the problem in the circuit and work your way backwards. Testing first the individual component then the wire leading to said component. Im sure other people will do it differently, but this is my method and it works for me, so I hope this helps. I couldn't find the exact diagram, so im basing this off the K8 model diagram.
I had this same problem with my cb550 and it was the battery.
Hope this helps
i grabbed the fault finder chart and ran through it after i push started it and ran it around the block 4 or 5 times.
with the bike running i measured the battery and got 13.6v @ 3k rpm and 15.2v @ 5k.
following the chart i counted the wires on the RR and went to section D and stopped the bike and started it again with a quick clutch drop in the garage.
probably shouldnt have gotten distracted @ this time as the wifey dropped in with shopping bags...so it idled for 5min.
remeasured the battery voltage again @5k, this time oddly it was @ ~9 so hoping this didnt create a false positive i continued with the lower than 14.8v reading and stopped the engine and disconnected what i THINk was the right connector for the generator (3 yellow wires, 1 white, 1 black). I think switched to OHMS and measured the resistance between the black/white and this gave me something like ~15Ohms.
following the chart this says its the fieldwinding in the generator and/or the brushes.
so before continuing on getting into chit that is already waaaay over my head in terms of understanding, should i be wary of the volt readings after the bike idled for so long?
if i go with the first reading (15.2v) and follow the chart its leaning towards the RR.
if i go with the ~9v reading through to the 15Ohms on the generator it leans toward the field windings/rotor?
or recharge and start over?
or should i just buck up and take it to a shop and feel the slow burn as they charge me my kids college?
It's an EMS so you will have a pair of wires going to field coil from regulator
The black is 'signal wire',the other return to regulator (and then ground)
Three white or yellow wires are stator windings, should have low ohms and not connect to ground, if your checking voltage there you need AC scale.
Have you had generator cover off to check brushes?
PJ
Hang on - if you're getting charging when the bike is running why are you pulling it apart? Just sounds like your battery is toast.
Agreed.
You were charging at the Higher RPM's. I would really look towards the battery. Charge it then leave it set overnight, see if it stays at over 12.3 Volts. If not replace it. If it does, then bypass the solinoid and go from your battery direct to the starter and see if it spins over. If it does, replace solinoid, if not. We need to talk more. Could be connections just need cleaned before blaming the Starter...
The "Click" meant your fuses were good, she's getting power, just not strong enough to crank over.
thanks a ton hoosier daddy, imma get to that tonight or tomorrow.
in the interim, does anyone know of the SMALLEST (size-wise) battery successfully used in a cafe-conversion on a CB750? stock everything, electric start, lights etc.
i believe the 750 stock is 14Ah? the battery i have now is newer sealed(6months riding time) but according to above advice MIGHT be dead. If so this gives me good incentive to look for new small form factor battery to put under the seat or build a custom box if i can find a powerful enough battery in the right size.
It doesn't have kickstart so you will need a 'larger' battery.
10Ahr sealed should work OK and is substantially smaller than a 14Ahr conventional.
PJ
Sounds like your battery is charging but not performing under load...it's probably toast. I would stick with the 14 ahr battery but stay with the closed cell/maintenance free. These bikes are notorious for having hard cold starts, you'll miss the slightly bigger battery. Based on your tests it sounds like the charging components are fine, so check your connections for corrosion, fit, etc.
would this one suffice? or should i really stick with the 14Ah? i plan on getting a seat in the next month or so and hiding that stock beast would be more than difficult.
http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-SLA1097(Other+Products).aspx?dsNavigation=N%7e44-2147384810-4285725181&Title=12V+10Ah+SLA+250+FASTON
Your going to have to use a motorcycle or similar battery.
The one in link would be fine if you were kickstart only.
Those terminals can't put out enough amps for electric start (need to be able to discharge at a minimum of 80 amps)
kk.. man its hard finding an SLA battery without those tabs. or at least it seems the F2 connectors are more common.
ill just go back to stock and not keyhole the bike.
Before you go and buy a battery, put some jumper leads on the bike and see if the electric starter works (could still be the starter motor that's the problem). If it fires up, then get a new battery.
