So, this fucking RD has been the bane of my existence. Still trying to learn the nuances of these damn things. I think its almost there now. The bike will start first kick every time, and it idles like a champ. If you give it quick throttle it just dies, if you move into the throttle it boggs a bit up until about 3k PM them takes off like a fucking bat. I have lots of troubleshooting pics and videos to hopefully help.
Bike has stock airbox, stock exhuast, 140 main jets (not sure about the others unless I take them all apart, it was a sudco kit).
First i cleaned the plugs, I left it ideling and then kept it at about 1/8th throttle (3k rpm) for about a minute where it seems to have the most issue. Killed it, pulled the plugs. Attached pics of the left and right plug. Each has a decent amount of oil all over them, is this normal or excessive?
I also have a couple of videos, hopefully these links work
Right cylinder timing
http://youtu.be/XKNSoQN86dA
Left cylinder timing
http://youtu.be/0lLpjGEgsC4
Quick Throttle Issues
http://youtu.be/ACmOJ42haSA
Gradual Throttle
http://youtu.be/q2kt1zIO0h4
I have full size versions of these files if you would like to get a better look. Everything seems to be good from a timing standpoint..
Gradual Throttle
