indianajonze
Active Member
I have a CB350 with brand new oil and recently rebuilt engine. When I kickstart it it isn't even spinning the motor. I have to bump start it and then ride it for a bit until the clutch starts to catch. At first I have very little power as if the clutch is "dragging" (not sure of the terms as of yet). I've adjusted the clutch cable many times to spec and once it's going the clutch works perfectly so I don't think it's an adjustment issue. Once it rides for a bit I can turn it off for about out 10 minutes and then kick it back up but if I leave it for about a half hour happens again.
Any ideas on what this could be? I'm in cottage country and need to to work to get home on Sunday.
Thanks a billion in advance
Pat
Pat
