help! tyre not center..
racedemon22
i have a big problem here... ihave check everything and lost how is my tyre not center with my body.. for your info this is honda cb400N half cafe hehehe... please give me some ideas guys.. i have check everything from bearing to axle but allthe thins were fine....
bent axle? does it roll smoothly?
swingarm could be bent, or the mount could be off... shocks could be bent also...
even worse is if the frame is bent. what happens when you spin the wheel? did you try taking it off and putting it back on?
+1.
Something looks very very wrong. Looks like the swingarm is bent to hell. Take the tire off, then the swingarm off. Put the swimgarm pivot bolt and the rear axle back in and see if they are pointing in the same angle.
If they are, then I would say the frame is junk.
In the first pic, the chain looks to be tracking true but the wheel is definetly not...does the wheel wobble when you spin it ? I say bent rim from the pics.
Can't really tell by the pics - but it could just be the rear sub-frame is bent and the guard / taillight is off-centre. The shocks still look straight (kinda).
You need to do some string-line measurements between front and rear wheels to check the wheels are aligned. If it's not, then possibly the swingarm is bent.
Was it straight before you dis-assembled it?
Look's OK to me, center line of tyre lines up with center of steering head so frame/swing arm isn't too far out of line.
remove rear section from frame horns, bikes been dropped and its all out of line at back end. May find back of frame tweaked?
Rear spring isn't sitting right, have you had the springs off dampers and fitted them upside down?
PJ
i try and spin the wheel and it does swing correctly... yup i try taking it off and putting it back in oledi...give me a headache...
yup, i think for abs the left side is quite to the right... later will check again... before, all the alignment were in place even the rear tyre was straight... luckily i take the pictures of the bike before the diassemble begun......
That tyre is COCKED. The top is to the right while the bottem seems near on . You must determine if the SA is bent. They can be straightened..Good luck.
