Help with '78 CB750 SOHC
Redliner
Over 1,000 Posts
I've been enlisted to build another bike, but I do have some questions along the way.
The owner wants a café/highway king and I'll be updating with pictures as soon as I get around to getting a decent phone ::)
OK, here's what we have: 1978 CB750 field find. Mostly there. Missing seat, side-covers, little stuff. I've made more from less ;D
My first questions just involve the differences with this particular model. I've worked on 76's, 70's, and a 72, but I believe I had read that the K7/K8 were very different in the engine.
Internally, what differences will I find between K0-K6 vs the K8?
Assuming I do a full piston replacement, would I just be able to put pistons/rings from a K0-K6 into this? I understand some were made for domed piston heads and some flat, so would the '78 work with this set?
http://www.ebay.com/itm/Honda-CB750-Piston-Set-of-4-1st-Oversize-0-25mm-OEM-Ref-13102-300-030-/200935035482?pt=Motorcycles_Parts_Accessories&hash=item2ec8a9525a&vxp=mtr
There are a few locations to pick up pistons.
You can go on Bike bandit and pull the different years up and check and see if they have the same part numbers.
http://www.partsnmore.com/parts/honda/cb750k/?filters[category]=engine
www.bikebandit.com
Partzilla has a better fiche and cross reference than bike bandit ( not saying I would recommend buying anything from them tho )
If you drill down to the part number of your year/ model, at the bottom it shows what other year/model bikes use the exact same part #. You didn't say whether you had a K or F.. so here is just an example:
http://www.partzilla.com/parts/detail/honda/HP-13101-410-003.html
Good news, bad news?? Well, I'm off the hook. The guy sold the two heaps and is now looking to get a GS750 to café. Sorry fellas.
I always use cmsnl to get part numbers, they have everything.
Then i google it and order from the cheapest :-[
