Help with cm400T rejetting
genosphere
So im fresh to this site and am hoping to get some reliable help.
I have a CM400T that has the mufflers off but the stock baffles still on and some cone filter in place of the air box. I have never rejetted carbs before so i dont know where to start exactly.
Im sort of on a budget and would like to not spend much, as far as i know i need keep upping the pilot jet size and lowering the main one at a time?
So to organize it a bit:
What exactly do i do?
What else must i do if anything other than above?
What parts/brand and where should i buy?
I want to get everything I need exactly so i dont over spend, which i have already done on a few on a few things that turned out not fitting/working.
Please help and thanks in advance.
(One other thing, i snapped the tip of the bolt that holds the exhaust onto the engine block, can barely screw it back on; so what is that bolt called or can i just pick one up that matches in a local auto/tool store? Dont know what to search for online is why i ask)
Unless you buy a trailer and drag it around behind with you for posing you would be better off re-fitting airbox and silencers.
It's just about impossible to make them run right with pods (I've tried and I know a LOT about Honda3 jet carbs)
Thanks, i guess.
Thought i did read/hear that if i were to take the rubber boots from the airbox-to-carbs and mod them to the pods i can rejet the mains "properly" though loosing 1-2hp, which i dont mind so long as the bike responds better than it is. I dont plan on racing and am going more for the look/style. Also heard that pods can be 'moody' when subjected to riding in the rain.
Though i still have the box if i decide to go back i would have to make new side covers to replace what i never had.
So if honda carbs are not an easy match for pods, which are? I heard getting larger carbs helps, and would velocity stacks work?
Thanks, the more info i get the more im learn and i want to learn as much as i can about bikes.
You need smaller carbs if you switch to non-CV, (Mikuni VM) usually around 6-8mm less than whats on there now.
That particular carb is really difficult to do anything with, unless you plug up some passages and re-drill new ones.
I haven't given up on them yet but as I don't have a 'late' 400 it makes things difficult to see changes
Perforated aluminium plate would work for sidecovers (or invent something different)
If you fit VM carbs you'll still have to work out jetting, none of them are 'right' even when seller says they are
Alrighty, i have been reading some of you input on other similar topics for more insight and its really helping. Thanks a bunch.
As for the pods/airbox dilemma, once i get back to my garage im going to look to see if i can put the box back on with out much problem seeing as i have already cut some tabs off which i think were just for the side covers.
At this point i would care less about putting the box on if it help the bike run close to normal. Making the fucking seat has been a head ache as it is... from a bad batch of bondo for the glass to the support of the rear being so "flappy" or "bendy" that it hits the wheel on every bump...
Was thinking of something like <a href=http://i.imgur.com/ItE4m.jpg?1>THIS</a> for the seat, seems simple enough and i could cover the existing rear frame without having to chop it all off, which i would do if i had a welder to slap on a new curved piece.
As for the side covers, ill probably just go simple and make some out of fiberglass unless i get a creative design in mind. Ill post some pics when i figure it all out. Shouldnt be to long now if i go back to the box, jetting might not be an issue any longer if i only have to adjust the pilot screw?
