Help with GS750 harness.
NBraun
Well as the title states im in some need of some help deciding what to do with my wiring harness on my 79 gs750. The PO tool the stock fender off, and put a new brake light on, as well as removing all of the turn signals.
My problem with the brake light is, it will only light up when the headlight is on, and it won't get brighter at all, plus he only hooked up two of the three wire.
As for the turn signals, it doesn't appear that he left the wires for the signals.
This is my dilema, i don't mind driving the bike with signals, but i want the light to work. Id be up for totally removing it and working on it, but i have no space really, plus its always under 10 degrees where i live, so it makes it a pain. I know the basics of wiring, but this would be the first time doing anything to this extent? Any help?
Thanks!
Looke for Bikecliff site link on the GSResources.
( http://members.dslextreme.com/users/bikecliff/) If your not a member over there as well you should join. It is a wealth of technical information on the GS bikes. It has manuals for most of the Suzukis on his site . Find the wiring diagram in the listed PDF.
If you have the correct brake switch's still on the bike the rest of the wiring should be lurking somewhere for you to tap back into. Use the manual to start searching in reverse for the right wire color combinations etc.
If he only has two of the three wires wired up to the light you will have to find the third missing wire to get the activated brake portion of the light to work. It is also possible that he wired the light up backward which would have the dual filiment on all the time effectively eliminating the brake light fnction by mistake.
Just some ideas,
GK
Thanks for the reply! I am a member on the resources and I have found the diagram. Suppose i just gotta go and dig in!
Thanks for posting about bikecliff. I have a GS850 I need to work on and its a great resource!
Well the PO must have been an idiot the new brake light has two wires, while the old one has three. He wired up the wire going to the headlamp and the ignition panel, but not the wire with the switches, making it pointless. He was also nice enough to cut the turn signal wires for me!
