anytime you have a capped off restrictive screen clamped right on the carb you are not allowing the air to run in a continuous fluid column, it has to make a turn and is too turbulent to be effectiveteddpage said:Emgo pods...sure. But a Uni-Filter...doubtful.
with those silly little pods it is the worst case, you couldn't really make it any worse if you fucking tried
you are asking the air to break up into little tiny streams (restriction) then it has to make a turn right away and it is not a homogeneous fluid column ....not efficient at all or able to react properly to the pulses of the intake port..
now large LONG unis or large LONG pods will be better, best case with an internal velocity type stack, but still not as good as a longer smooth tube to straighten the air and allow it to be fluid.and the airbox adds resonance as well and is a big part of the picture for flexability of the power.
some hi spec engines use variable length velocity stacks that are movable by servo motors to the resonance of tune of the intake
but you will never
it is just so fucking hilarious every time i see it ....
