Help with my CB125?
KP111
First off I am new to this site, so I apologize if this is posted in the wrong thread. I have a 78 CB125s and the carb is driving me mad. I have had to clean the "slow jet" weekly due to clogging. The inside of my gas tank is slightly rusted and I cleaned it out the best I could, and replaced the fuel filter. It will start up and idle fine, until i get on the throttle, then it cuts out. Is it time to consider sealing my tank? Any suggestions would be much appreciated.
Acid clean the tank or seal it.
Not running a short exhaust or pod filter are you? That's a sure fire way to make a Honda single run poorly
Walmart.
Use "the works" toilet bowl cleaner.
If you search around you will find some write ups.
Some tanks just can't be cleaned though.
