That was for a vaccum operated petcock. should be a bung on the back side of petcock. If your not using stock tank. Probably not needed. At that point, remove it and plug the bungs in the carb boots.
Looks like there are two barbs on the left boot and one on the right. 1 on left goes to petcock. the other two are for carb sync and should be blocked off with a cap when running.
If you have to stock petcock, the vacuum operated fuel cutoff is probably rotted out anyway. You'll probably want to replace it with a traditional on/off/reserve petcock and cap off those two ports.
Thanks. I now have a leak on the boot where that comes out of. (between carburetor and engine) looking for a replacement but what exactly is that piece called?
