Help with wire harness cb350
Hi guys....I took a break from the project but I've been messing with it again.
It their a way that I can test this switch for the brake lights.
Thanks
Use a multimeter to check continuity between the two wires. You should get a reading pretty close to zero Ohms when the switch is activated.
The switch simply connects the 2 wires when it is pulled, so you can unplug it and use a test light to check it.
They're as simple as it gets - might be incorrectly adjusted or dirty inside if it doesn't work.
Thanks Hillsy
Just did a little experiment to test it and it doesn't seem to work. So I'll try to adjust it or clean it..
Thanks
Well ... I justed finish adjusting the switch and for my luck neither brake switch work.
So if anybody can direct me where can I purchase them I'll appreciate it
Thanks
Checked out eBay and ordered the parts and I got them on Saturday .
I got my parts from Classiccycleparts and they ship quick.
Will be installing during the week and I'll get back with the results .
Thanks
Hi Guys after almost 2 years, I finally started working back on this project.
Should by riding it for this summer...
thanks
