HELPStarting and running
chrisf
Over 1,000 Posts
OK, so I'm trying to move forward with getting the CB360 to run right. She actually ran better last night. I have two questions:
1.) I'm running stock CV carbs. When the bike is running and I twist the throttle, nothing happens. I see (and feel) the carbs opening to their max, but revs don't raise--nothing happens. The slides move freely, so why will the bike idle but not rev?
2.) Left side is not sparking at all. I tried the left sprak plug on the right side and it's getting spark. I tried the right-side sparky on the left side and...nothing. I test the black feed wire going into the coil and it's getting energized. Is the coil bad? Perhaps the points aren't triggering the coil?
Any help is well appreciated. I'd like to get the bike sorted ASAP so I can ride her this weekend and troubleshoot as much as possible before the April 10th devilvery.
--Cheers, Chris
Re: Starting and running
Make sure the points are clean and that they are adjusted properly. The coil only gets a short time to charge before the points break again. If they are too far either way then it wont work. I'm not sure what the specification on a 360 is but I can dig up some 350 numbers pretty fast if you need.
As far as the carbs go I have no suggestions. I switched to Mikunis for a reason, I positively hate the stock carbs on the 350 and I imagine the ones on the 360 are very similar.
If the slide is moving up but the bike doesn't rev then maybe the main jet is plugged? The brass jet in the base of the carb comes out and has very tiny holes in it. Pull the bowl off and take the slide out then push that jet out and clean it really well. Do the same with the other jet. You should also make sure the floats are set correctly and that the carbs have enough fuel in them for the jet to pick it up.
I spent a lot of time fighting with my Keihin CVs on the 350 and finally gave up, if you can make those Mikunis work I would suggest that.
we're on completely different pages :)
You were right about the timing. The points were way out of wack. Both cylinders woke right up and reved their nuts off. Seems I now have the oposite problem. It's getting late, so hopefully it's just a cable adjustment issue.
When I played with the points, I changed the oil. There was quite a bit of what looked like rusty shit in it. I'll run a couple quarts through tomorrow.
--Cheers, Chris
Heh, maybe we should just combine the two threads into one big 'carburetors suck' thread and figure out some kind of fuel injection conversion.
I don't know how different the 350 and 360 motors are or if you have had to do any of this to your 350 but I have had to tinker with mine a lot. For my 350 I made a timing light out of an old turn signal bulb and some wires and alligator clips. Solder the wires on to the bulb then ground one clip and connect the other to the nut where the wire goes to the coils. For a 350 start with the left point and turn the base plate until it is timed properly. You have to take the side cover off and use the timing marks, the bulb should shut off right as the 'LF' mark passes the index mark on the generator. This is much easier to accomplish with the plugs out. Make sure you only turn the engine to the left.
If they are revving too much it could just be a carburetor issue (idle screw) or timing so just check the ignition timing and make sure its right, they are kinda picky.
chris, would you like to stay in california for a few days? im having trouble tuning my 360. please keep up this post. i think it will help me .
ok, still no fucking throttle. I actually stick my hand down and twist the throttle on the carbs--nothing. WTF?? Would a leaking diaphram cause a nonresponse throttle??
What the fuck would cause a carb not to respond to throttle input?
Please help because I'm out my mind frustrated.
--chris
--chris
Chris, are you saying the butterflies open and the slides do not move ? How does it idle ? Doug
that's exactly right. I need to look closer to see if the slides move. I don't think they are moving. The bike idles great. What do you think?
--Chris
If the diaphragms are damaged the slides will not move. Were they in good shape when you put them on the bike?
Can you move the slides with your fingers easily? Maybe they are stuck in the carb bodies. Make sure the air passages are clear into the vacuum chamber at the top of the carb and that the slide is in the right way. The holes in the bottom of the slide go on the engine side.
The slides move freely by finger. Maybe I didn't get them seated properly. It does sound like a cv leak issue, doesn't it?
--chris
--chris
I know with the Mikuni you have to take care when seating the diaphram, also the locating tab. Has the engine idled ? have you tried a shot of starter fluid ? May prove it is fuel related
