HIDs on a cb750????
BArTY
I was just curious how many of you run HID lights on your CB750s. I just bought a kit for my truck from DDMtuning.com and freaking love them! I'd like to add more light to the front of my bike as well, but I'm not sure the size bulb or if anyone has any recommendations for me. Any info is greatly appreciated. Thanks!
I had issues running the halogen bulbs on my cb750f... It seemed to draw faster than my stator could charge..
It was fine when the bike was running but when idle or starting it drained the battery big time...
I had to put a on/off switch for the headlight so I can start the bike with the headlight off...
I ran the bike during the day with the light off and only ran the light at night...
I cant imagine what an HID unit would do to the bike's charging system...
you should try it and let us know :)
You probably have 110~10w alternator. (9.5~10 amps)
You need about 4.5~5amps for normal running so you don't have a lot of reserve, about 60watts (or, about stock headlight wattage)
PJ
the HID kits run at 35W or 55W with their own balasts. a friend of mine has them on his cbr1000, but its a way newer bike so i was just curious if anyone had them running on their cb750s. the difference in visibility is literally, night and day
h.i.d. will draw considerably more amperage when cold (which is why you'd need to be able to turn it off during warm up of bike), after they warm up they arent too bad (low wattage versions), but those lights get damn hot... im not sure id want that near my rats nest. that and you have to find a place for the ballast... they dont like to be blinked, some can take up to 10 min. to come back on after they have been turned off (cheap kits at least) all sorts of issues they could cause with our less than stellar charging systems...
i would avoid hids just because of all the trouble...
anyone consider doing loads of high intensity leds? those things are damn bright! and the distance is decent too....
anyone look into a custom stator for these bikes? im sure it wouldnt be difficult to wind up more coils then stock and build a better one... i have some experience with this but my only issue would be getting the correct magnets in order to make it work. if my thinking is right... twice the coils means twice the amps.... and you should be able to get rid of the no charge at idle problem if their are more coils, that are smaller then stock.
hmmm you just may be on to something. i'm going to look into this more. the visibility is just amazing with HIDs and i'm sure there is a way we can make it work.
