High valve clearance on #1 exhaust cylinder - cause for low compression?
Jimbonaut
Over 1,000 Posts
DTT SUPPORTER
Evenin' all, I did a valve clearance check today on my '81 CB750, the numbers looked like this (from left to right, sitting on the bike) -
Exhaust - 0.004, 0.009, 0.002. 0.002, 0.003, 0.003, 0.004, 0.003
Intake - 0.004, 0.004, 0.004, 0.005, 0.004, 0.003, 0.006, 0.004
The compression test I ran the other day gave these numbers (from left to right, sitting on the bike) -
125, 150, 145, 150
Am I right in thinking the low compression on #1 cylinder could be caused by the high clearance on one of #1 cylinder's exhaust valves?
Are the other valve clearances ok (0.005 is I believe a good number to aim for) - would my numbers be considered within the boundaries of "healthy valve clearances"? I should mention, I followed the steps laid out in the Clymers manual - looking at the reference mark on the right-hand end of the exhaust cam.
Cheers,
- J
Your thinking is back to front - too little clearance can affect compression, not too much clearance.
Those exhaust clearances should be larger than the intakes on most bikes - exhaust valves run hotter than intakes hence the greater clearance spec.
Oddly, the exhaust and intake callout is the same on the DOHC. .005 +.001/-.002. So, basically .003 to .006 is in spec per the manual.
Yep, they all appear to be ok except the .009 but that won't effect your compression. Looks like you need to do the oil in the cylinder and see if compression improves, if it does, it's rings or bore. If it doesn't you need a leak down test to see where you are losing compression.
Hmmm, well that's that theory shot! Still, I'm really enjoying this whole process - it's the first time I've got this deep down and dirty with an engine and I find the diagnostic aspect fascinating. I'm going to run the valve check again, and then I'll try the teaspoon-of-oil-in-the-cylinder routine and see what gives. I pour the oil into the spark plug hole, right?
I'll keep you posted, and will no doubt be back here with the next set of questions for you!
Cheers from MTL,
-J
Yes - a bit weird when pretty much all the others have greater clearance specs for exhaust valves.
I sat and looked at the manual for a good 10 minutes when I was rebuilding my engine a couple months ago. Then scoured Google. Apparently, the guys at Honda were right. Seemed off to me too. I set them at .006.
Sent from my SAMSUNG-SM-N920A using Tapatalk
The old SOHC guys I knew used to set the clearances to the smaller tolerances claiming it gave a bees-dick of extra lift and therefore extra power.
I guess it's easier to keep an eye on / adjust screw tappets than shims.
I redid the valve checks and got pretty much the same numbers. Poured a teaspoon of oil into cylinder #1, cranked the engine and got a reading of 180+psi on the compression test.
Cylinder 1's exhaust valves are 0.004 and 0.009.
Piston ring problem? Possible valve problem? The leak down test is from what I'm told the best way to diagnose the problem but I don't have a leak down tester, at least not yet. I'm going to re-shim the valves to get as close to 0.005 across the board, and will then try to work on the low compression on #1 cylinder. Any suggestions on the plan of attack gratefully received!
pull all sparkplugs one cylinder at a time with plug in rotate crank with wrench on crank bolt in a quiet shop helps to have pipes removed and carbs or held wot
when on compression stroke for that cylinder simply listen for hissing its an okie leakdown will tell you if a valve is leaking
my bett is stuck rings or badly worn iyou will want to do a valve jo\b as well,at the minimum all valves need to be yanked and service limits checked,cause the head is coming off time to dump 500-a grand into it no easy around it bub
how does it run and ride ? if ok ?me i would ride and enjoy it,when it quits get something else
dont fall in love with it
how many miles ?
Cost me round about $200 to rebuild mine a couple months ago.
If you can do it yourself, it doesn't cost much.
Since the oil increased the pressure you are 90% sure now it is rings, either stuck or worn, the leakdown would only be needed if the oil didn't increase the compression by much.
I'm hoping to maintain the engine as much as I can and within the limits of my (rather limited!) abilities - I'll do whatever I can to keep the old girl running and running as well was possible. How does it run? Excellent question - I bought it as a non-starter and after cleaning it up a bit (carbs, airbox, spark plugs etc...) got it running, but not on the road.
Think I'll leave the valve job for now, but will investigate the piston rings once I have the engine out of the frame. Thanks for the info on the cylinder leak test xb33, and also for your avatar
Might as well do the valves while you have it apart. You'll have to pull the head a second time to do them. Takes no time to lap them back in if they are serviceable.
ride it like it is for a while you wont harm it learn to tune it and like it get it good and hot and during cooldown pop out the plugs and seafoam or marvel mystery or just plain atf the cylinders it could free a stuck carbon fouled or sometimes they get parked that last time,the tank/carbs slowly drain gas into the cylinders and it turns to sugar and sticks up the rings this type of stuck ring has the definate possibility of rehab via solvent soaking many claim to have had some success and its cheap thing to try
does the engine smell like bad gas ? ,you can always tell the smell is impossible to remove
just be sure to never crank any engine with the plugs in and a liquid soak,you gotta remove it first
I was going to suggest the seafoam or solvent in the one bad cylinder as well. It is worth a try first because the rest of the cylinders are fine.
I like this suggestion - what would be the exact procedure for doing it? And can I ask how to remove the solvent from the cylinder before firing it up?
The bike had been sitting for a few years when I bought it - the carbs were totally fouled up with rust and varnish. There was a smell of old gas, yeah - either I'm just used to it by now or it's not there any more - I'll stick my noggin in there tomorrow and let you know.
Stick some ATF in the cylinder and let it chill for a couple days. I have one of these syringes with vinyl tubing that's very useful, should be able to use something like this. Runs it for a bit and then check the compression to see if the rings freed up. Then change the oil either way.
https://www.amazon.com/gp/aw/d/B000HI0UK0/ref=mp_s_a_1_1?ie=UTF8&qid=1480124791&sr=8-1&pi=SY200_QL40&keywords=fluid+syringe+automotive&dpPl=1&dpID=318jhD6Az9L&ref=plSrch
Hey man thanks a lot for the suggestion - not wanting to be a ball ache or anything but how much fluid am I looking at? I don't wanna mess anything up in there. I leave it in the cylinder for a few days, then crank the engine? Spark plugs out? Sorry for all the questions, just want to make sure I do it right.
Thanks a million,
-J
