hmmm... i wonder.
VonYinzer
Over 10,000 Posts
So I installed tapered bearings in the 350 awhile back, and it seemed a bit too easy now after reading the posts from some others on here. Once the original races were removed, and the new ones installed, everything seemed to line up just right without any spacers. They were pressed into the neck to the stock lip. With the bearing layed in, the tops of the bearings are seemongly right where they need to be. The trees seat well on them, and have smooth full travel. The trees also cover the sides of the bearing /neck right, seemingly. Should there be a spacer? It really doesnt seem as if there needs to be one. The bearing set was from pyramid, and they said it was specifically designed for the 350, but who the hell knows...
Thanks, Mike.
usually, bottom yoke rubs on frame when bearings are properly seated
almost always need washer under stem bearing
PJ
PJ
Thanks PJ. Im going to working on getting the front end together later today... Ill see where everything sits for sure.
Are you sure the bottom bearing race is pressed right up against the bottom of the steering tube? I used the same kit and I needed the thick spacer.
Yup. My buddy even took it to work and used a special press to be sure.
My g model race lump requires a refurbishing,,(someone said it looked vandalized,,,"no it was crashed") and I have the same bearings to install, thanks for the heads up!!
Well fuck me sideways... I need to tap out the bottom race. Its too deep. Only issue is that the bearing kit came with no spacers of any kind. I know i can find something that works, but I have no clue now as to the thickness needed. Anyone remember roughly what you used? It seems like maybe 1/8" should be adequate?
Thanks, Mike.
Thanks Primo... Also, I realized i wrote that all wrong. I need to pull the bearing off of the stem/lower tree and go from there...
To be sure, if you still have the old races and ball bearings you can put those together and measure them compared to the tapered bearings on a flat table
Havent had a chance to look, but I think I saved em. I share a small garage with a guy whos a little messier than me though, so who know where they are.
