Holy Forks bikeBoy !
DreadRock
Bang Cut Grind ..Dam Did I Need That Part ?
DTT BOTM WINNER
was wondering if anyone knows what forks will fit a 75 XS500b . found a pair of XS1100 ones(think to long) and XS400 ones(maybe to short) not sure what to put on but i do know that i would like to keep the stock wheel if i can ? has anyone put newer forks on there XS say like FZRs or FZs ?
I have been told that all XS forks/wheels use the same diameter axle. That said you should be fine keeping your wheel if you stay in the XS family. Naything else and you may need to get different bearings and have spacers made. Also, I think the xs400 and xs500 use the same forks... I think. I know the 650 forks are longer by a bit.
And from what I know, xs400 fork tubes are 33mm diameter, xs650 forks are either 34 or 35mm depending on year, xs750 forks are 37mm diameter. Not sure about xs1100 fork dia, but count on at least 37mm.
So if you want to swap between models, you may need to do a whole front end swap.
Yeah, I was just going to say, well look at that, there's a fork tube diameter sticky up there, and I'm not entirely accurate! Neat.
i know the xs500s are 34mm . just want to make sure im not riding a cafe chopper lol my trees are ok with some podercoating . but if i have to go another way lil bigger isnt so bad . think ill try for xs400 !
I have some xs750 forks that are 35mm, and 36mm. The 35 mm are for sale along with the triple trees if you're interested.
not sure if they fit a xs 500. i think a 400 and a 650 XS will fit if pre 1976. not sure about the xs750 ? can u PM info thanks
