Honda 400 only half the engine running
Bobby4Prezz
i have a hondamatic 400, only half the engine is running, i changed the spark plugs and only half is getting spark, the wires are not long enough for me to send the running one over to the other side to check to see if is just the wire, but can i replace only the wire? or do i need a whole new coil setup? any help with this would be great!
Doesn't it have a dual lead coil?
If one side sparks, the other side has to, unless there is an internal break in insulation?
when i am running the bike it drags, and when i remove the spark plug on the one side it doesnt seem to make any difference? could it be that that side kicks in while the bike is driving? i have no idea about these things
take plugs out and look at them
they should be roughly same colour.
Can't remember if you can change just the leads on those coils, I think you can.
tried taking out the plugs and switching them, they look about the same
It may be blocked pilot jet, bike will run on both cylinders when throttle is opened as it transitions onto mainjet (or needle/needle jet at lower throttle openings)
There probably isn't anything wrong with coil/plugs
so why is the bike running so sluggish? is it a problem with my carbs? and if so where do i start to fix them?
If fuel is being restricted getting into the engine, it will be sluggish.
You need to remove the carbs and clean out all the jets with compressed air. If you don't feel confident doing that, you can take them to a shop to have them cleaned out (I have no idea what that would cost nowadays, but I remember a local bike guy near me charged about $30 some years ago).
Then flush the fuel tank, get some new fuel lines (and filters) and re-assemble.
A workshop manual is a good thing to buy first up if you don't already have one.
