Honda CB 200 Stator
caveman592
So I think I f'd up. I have the plug on my stator broken. I didn't know about the spring on the wire for taking it apart. is there any way to remove the rest of the plug without taking apart the engine. Beacuse otherwise I have to try and epoxy it with it attached to the engine still which would be hard. So was I stupid? Here is some pics.
Here are more pics
That is the neutral indicator switch, it just follows the stators wire loom.
It's not part of the charging system. You should be fine without it.
Now that I look closer, you will want to make sure that the broken part of the plug doesn't pop out.
Otherwise it may leak oil. Maybe use some grey RTV silicone to glue it back together? ...find an appropriate sized plug?
