J.K.L.P
I've recently finished building a CB350 and have ridden it over 100km since completion with no problems at all, revs out clean, pulls well through all the gears, etc. Last week i was riding home and it stalled at a set of lights, not unusual as i was playing the with the idle speed screws before leaving. Managed to get back home without any issues and everything appeared fine.
Once home i attempted to start it again which proved very difficult, always started on 1 or 2 kicks. Once i managed to get it started after about 20 kicks i noticed that it was running on only the right cylinder only and nothing out the left. Over the last week i have been chasing this issue and have done the following with still no success in getting the left cylinder to fire. It will run fine on the right cylinder with an occasional huge backfire from the left side out the exhaust.
Compression check measures 170psi on both cylinders
Pulled apart left carby, cleaned it out with carby cleaner and checked diaphragm and jets all ok
Checked timing, its spot on
Sprayed aerostart down the carby while running, still doesn't fire
Checked the spark plug is firing under compression with a color tune plug, no problems
Checked exhaust to make sure there was no blockage
Checked battery for full voltage, reads 12.6v
Pulled off the valve inspection covers to make sure the valves are opening and the clearance was correct
At this point i have no idea what else to try and can't see any reason why it shouldn't run on both cylinder but it just doesn't. No matter what i try it will only run on the right with the occasional huge backfire out the left.
Any advice would be much appreciated. Thanks in advance.
