Rydog400f
So just finished rebuilding the 360 and I can't get it to sync. I've adjusted the valves, set the timing with a pamco electronic ignition, and checked for vacuum leaks. When I hook up the sync gauge no matter which way I turn the screw it won't sync. The throttle cables are lubed and not sticking either.
So I was messing with it today and noticed if I pull the right spark plug wire off it idles fine and revs fine with just the left cylinder. When I attach the right plug again the revs shoot up. Same thing if I start it with only the right plug attached, just shoots right up. I have the mixture screws 1 and a half turns out as the manual states to start with. I also noticed I can feel slight electric shock from the handle bar when the right plug is not attached and the bike is running.
Any help is much appreciated. I wanna ride!
