Honda CB360T Rear Sets Now Available
J-Rod10
Over 1,000 Posts
DTT BOTM WINNER
Finally got a chance to get a set together for the 360.
Here's the brake side. Same as my 350 set up, these will make use of the stock brake rod/light switch by using the custom pivot piece I've built for them. So there is no relocating the switch, or running an aftermarket rod.
These, as all of our others, are aluminum pegs/levers/linkage rods with heim joints.
Same as the other bike specific, they will be $195 + $12.80 shipping.
Here are some pics of the brake side. Have to machine a lever for the shift side, but, it'll look just like all of our others.
Just double checking, this is a bolt on kit? If so i'll take one. Not on your site yet, can we do paypal?
It will require either welding a tab I provide onto the stock lug of your shifter. Simple to do. Typically costs $5-$10 locally if you can't do it yourself. Or, you can cut the lever off, and drill a hole in it to fit the provided.
The tab, is the part with the #1 on it.
If you are interested, pm me an address to send a PayPal invoice to.
Thanks,
Jarred
lipuid said:
Does it clear the stock side cl exhaust on the left side?
Bud you may be confused. The Factory CL high pipes are above the sets. They clear everything all the time. Its the CB pipes and 2-1's that create the issues. Similar to what he has pictured.
Precisely, no issues with the high pipes. You can do just about whatever you want down there with the high pipes.
