Honda CB400N 1979 electrical problem. Help plz?
TwinEagle___
Hi every one,
Thanks for the help on my previous problem. It was indeed a clogged up carb + broken spark plugs.
My project is nearing completion: i resprayed the tank as well.
The only thing left is the problem with the electrics. I bought a led light block an mounted it on the end of my loop.
Connected it as well, indicators work perfect but I have a problem with brake and regular rear light. I have 1 cable that gives me 12V to the rear, but only when in park mode. When ignition is on, front light works but rear doesn't.
Brake light never works?
The light itself works: when I change the wires, i get a permanent brake light (also in park mode).
I did disconnect the connector for all of the wires to the dashboard but I think that shouldn't be the cause of the problem?
Kind regards and thanks for the help,
Wouter Smet
Belgium
